Perform this procedure to display the IPsec routes configured on the Fabric IPsec Gateway Virtual Machine (VM).
  1. Enter Fabric IPsec Gateway Configuration mode:
    enable
    virtual-service WORD<1-128> console
    Type CTRL+Y to exit the console.
  2. Display IPsec routes installed:
    show ipsec-routes
Displaying the IPsec routes configured on Fabric IPsec Gateway VM:
Switch:1> enable
Switch:1# virtual-service figw console
Connected to domain figw
Escape character is ^Y
  <cr>
FIGW> show ipsec-routes
192.0.2.30 via 192.0.2.20 dev eth0.125  mtu lock 1950
192.0.2.1/24 dev eth0.30  proto kernel  scope link  src 192.0.2.2
192.0.2.10 via 192.0.2.45 dev eth0.30
192.0.2.100/24 dev eth0.125  proto kernel  scope link  src 192.0.2.60
192.0.2.11/16 dev docker0  proto kernel  scope link  src 192.0.2.12 linkdown
